Date/Time: Thu, 19 Sep 2024 16:08:10 +0000
"M" indicator for real time data
View Count: 1126
[2014-02-21 17:56:35] |
User37300 - Posts: 3 |
Hi, I am trying to run real time data on symbols YM-201403-ECBOT ES-201403-GLOBEX NQ-201403-GLOBEX = I trade IB brokers. After set up of SC Exchange data, these are not downloaded on for above symbols, and there is no "M" indicator. Could you pls advice? Thanks Regards Roman |
[2014-02-22 06:16:21] |
We apologize for the delay with responding. We see that you have selected "SC Exchange Data". You need to select Interactive Brokers as the service to access the real-time CME data: https://www.sierrachart.com/index.php?l=doc/IB.php#SetupInstructions For more information, refer to: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration We do not normally get behind on these types of support requests, but we have been under a heavier than usual support load. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-22 06:17:55
