Date/Time: Wed, 26 Feb 2025 11:44:09 +0000
Lookup function in spreadsheets
View Count: 896
[2021-01-20 09:02:34]
User261741 - Posts: 22
Hi!
Just to check, spreadsheet lookup function is no longer supported?
Do you plan to implement it again any time soon?
Thanks in advance...
[2021-01-20 14:02:03]
There have been no changes with spreadsheet functionality in years. Specifically what function are you referring to?
[2021-01-20 16:47:11]
LOOKUP function. I saw that this was supported previously, now there is only VLOOKUP and HLOOKUP...
I can mwork it around with couple of auxiliary columns to replicate LOOKUP, but I am already using all 60 columns for formulas.
I need it to simply find first and last occurence of specific value in a range...
[2021-01-21 00:00:28]
Ok this was only in old spreadsheets which were discontinued years ago. The available functions are documented here:
Spreadsheet Functions
Date Time Of Last Edit: 2021-01-21 00:00:43
[2021-05-19 21:39:55]
j4ytr4der_ - Posts: 946
I came here also looking for the plain LOOKUP() function, as I need to find the *last* occurrence of a value in a VLOOKUP, not the first. I know there are other ways to get the result but was hoping to simply use this function.
Date Time Of Last Edit: 2021-05-19 21:40:07
[2021-05-19 21:42:28]
Actually it looks like GetCorrespondingMatch() is the preferred approach now, I will give that a shot.
