Date/Time: Mon, 25 Nov 2024 19:49:19 +0000
submitting ib order , using data help
View Count: 1208
[2014-02-21 16:10:31] |
gabby alindogan - Posts: 49 |
Hi. I want to submit auto trades into IB and keep using FXCm data. Being that the symbols are unmatched, how would I submit to ib and use fxcm data. ex eur/usd in fxcm is eur.usd-idealpro-cash. thanks |
[2014-02-21 18:16:13] |
This is going to be made easier in about two weeks. For now you need to follow the instructions here: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-21 20:06:59] |
Hi. I followed the directions step-by-step. Sierra1-my original one has SC Forex. I then installed and configured Sierra_IB with IB trading service. I get stuck in step4 of "Sharing data between...." When I click find symbol, the instance drop box is grayed out and only has the value of "Interactive Broker (this instance). How do I pull any chart using sierra 1 as the source. Thanks
[2014-02-21 20:26:39] |
This issue is explained here: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html#SharingWithAdminAccess Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-21 23:58:42] |
Thanks that worked. I have a question regarding using fxcm as data and autotrading with IB. Let' take EUR.USD (eur.usd-idealrpo-cash in IB). If I a basing my buy triggers from fxcm data (ex adx(x) >20 then submit buyorder) but submitting a limit order using ib's data-like bid/offer ) Do I have to have the chart of eur.usd open using fxcm instance AND eur.usd-idealpro-cash IB instance chart open as well? |
[2014-02-22 13:40:13] |
As a followup question to post 5, if I want to create an indicator for a 60m chart based on 5/10/30m timeframe, I realize that I need to open 3 charts. If I trade x 50 Fx tickers, I am now looking at 150 charts open. Given the use of fxcm SC Forex data, am I close to some limit (performance issues or otherwise) that will make autotrading not advisable? Thanks.
[2014-02-24 18:55:27] |
No.Refer to: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html#Sharing Given the use of fxcm SC Forex data, am I close to some limit (performance issues or otherwise) that will make autotrading not advisable? Thanks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-24 18:56:09
[2014-02-28 13:48:56] |
Please reference post #6 regarding having 150 charts open(charts 1,2,3,4 referenced by chart 5 for a price/overlay study PER ticker) I was wondering if there is a way to set up only about 5 charts which would do 1 ticker, then programatically load the next ticker at a time, let's say every 10 seconds,--possible to load ticker, calculate the indicators, fire off limit orders, then go on to next ticker ... |
[2014-02-28 18:41:20] |
It is possible to programmatically change the symbol of the chart. You need to use this ACSIL variable: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scDataFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
