Date/Time: Thu, 20 Feb 2025 20:41:08 +0000
Replay tick by tick
View Count: 724
[2021-01-19 04:11:43] |
User432142 - Posts: 44 |
dear, Replay mode was used to worked tick by tick few weeks ago but now it start to work second by second after l updated platform. l dont know which version l was using thanks |
[2021-01-19 05:18:08] |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
