Date/Time: Fri, 18 Sep 2026 15:37:20 +0000
Opening of chartbooks
View Count: 1348
| [2014-02-21 15:31:39] |
| User22591 - Posts: 133 |
I do have issues at times a little more than I would like where my chartbooks will not open when we try to have them open. Is there an explanations?
| [2014-02-21 17:59:55] |
So you are saying you do not see your Chartbook when you open it? This would indicate there are no charts in it. If so, what is the file size of the Chartbook? You should be able to see the file sizes when you select File >> Open Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-21 18:01:18
