Date/Time: Thu, 20 Feb 2025 20:41:29 +0000
Time line text
View Count: 447
[2021-01-18 17:36:19] |
User575399 - Posts: 326 |
I cannot figure out why this text will not show up on my chart at this specific time. I have other time line texts that work perfect. Any ideas?
Private File Private File |
[2021-01-18 18:28:42] |
John - SC Support - Posts: 38093 |
The Time Line study will not work with a TPO chart. Even using the Study/Price Overlay will not work with this particular item.
[2021-01-18 18:40:18] |
It’s not a TPO chart . It’s a 5 tick renko and I have other time lines that work just fine on it. Just this one will not
[2021-01-18 18:51:02] |
Attach the chart to this thread using these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-18 19:11:45] |
Here you go
Date Time Of Last Edit: 2021-01-18 19:12:00
Private File |
[2021-01-18 20:28:27] |
The problem is that you only allowed a 10 minute range to try and match to a bar (Allowed Range for Match in Minutes), but in this case, the bars surrounding 11:00 are at 10:32:18 and 11:29:53. Therefore the Time Line would not match to either of these bars. Increasing this Input to 45 minutes will display the line. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
