Date/Time: Fri, 21 Feb 2025 18:25:39 +0000
[User Discussion] - IP address for data feed and order routing
View Count: 785
[2021-01-17 02:48:34] |
User5044343 - Posts: 68 |
Im going to switch over to tt fix service and denali data source. I wanted to colocate a server but wanted to decide where I can place it depending on the datacenter's latency to the tt fix and denali. How does one get those IP addresses ? |
[2021-01-18 09:45:49] |
You can ping this address and get its IP: futurestrading2.sierracharts.com Although it will not respond to a ping. But in the process you will see the IP. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-19 06:49:09] |
2-4 ms to .1 of that subnet. Thank you. |
[2021-01-21 19:24:28] |
User311344 - Posts: 142 |
So how did you check the latency with no response from ping?
[2021-01-21 19:33:56] |
You cannot check.
[2021-01-21 21:55:59] |
Well it seemed like it was possible to check. @sierra maybe you could add that information to heartbeat logging in the Message Log? I miss the possibility to check that with simple ping command and this information crucial when trading orderflow. |
