Date/Time: Fri, 10 Jan 2025 20:15:18 +0000
Hide and Show ALL studies on a chart
View Count: 1477
[2014-02-21 14:09:26] |
User025822 - Posts: 35 |
Sierra chart Engineers... The current way to hide or show studies, without having to save and change study collections, works at an individual level by selecting which ones you want to hide or see. This can be done from the chart by right clicking on the chart header or by opening the chart studies window and selecting one by one the studies to hide/unhide. Can something be implemented in a future release to be able Hide ALL and Show ALL studies in a chart from the chart header menu? I have created a visual example of how this could be implemented. Please have a look at attached image. Thank you |
HideAllMenu.jpg / V - Attached On 2014-02-21 14:08:35 UTC - Size: 86.63 KB - 362 views |
[2014-02-24 18:39:32] |
We will take this as a suggestion.
[2016-10-05 14:41:56] |
Just a quick note to say Thank you to the Sierra Charts team for implementing this on a previous release. Now it is possible to Hide and Unhide All studies with one click or keyboard shortcut. Thank you. |
