Date/Time: Thu, 20 Feb 2025 20:15:35 +0000
Denali Historical Data
View Count: 608
[2021-01-15 21:31:15] |
User162589 - Posts: 2 |
Good afternoon, I believe i enabled the Denali feed on my service package for historical only, however, I still cannot get historical data past the middle of December. Any idea what I should do to fix this? Thanks, |
[2021-01-15 22:05:56] |
John - SC Support - Posts: 38089 |
You have not enabled the Denali Exchange Data Feed. You can do so from the following link and selecting the pulldown in #2. Be sure to select the option Denali Exchange Data Feeds for All Services. https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation&UserID=159948#DenaliExchangeDataFeed You do not need to complete the agreements or anything else. Just make the selection and then select the Update/Set button to the right. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
