Date/Time: Tue, 06 Oct 2026 00:47:18 +0000
Chart settings changes in Trial version
View Count: 838
[2021-01-15 19:17:30]
User106338 - Posts: 3
I am currently working with your trial version.
I am making changes to the graphics displayed and have been able to make some of the changes I would like to see
However, when attempting to change some of the color options and border options for the bar/candle prints they do not get implemented-please advise (I have been able to change spacing and background color)
Also, I wanted to know if I get this set up how I like it, when I activate service will my changes stay in effect or will I have to redo?
Thank you,
John
[2021-01-15 20:08:36]
John - SC Support - Posts: 48114
You will not have to redo your settings. They will still be there.
We would need to know exactly what items you were changing and where you expected to see the changes. You can also give us a screenshot, which would be helpful. Refer to the following for how to post a screenshot:
[2021-01-15 20:34:14]
http://www.sierrachart.com/image.php?Image=1610742602628.png
I would like a black outline on the down bars and would like to fill and outline the up bars
These options appear listed under Graphic settings Global but I can't get the changes to take
Other changes have taken effect after ok and apply from the menu
Please advise
Thank you
[2021-01-16 04:03:22]
You therefore will have to change the chart specific Graphics Settings because that chart is set to use its own settings apparently. Refer to:
Graphics Settings: Introduction
