Date/Time: Tue, 17 Nov 2026 12:53:22 +0000
Nymex / CL
View Count: 1085
| [2021-01-15 18:02:25] |
| Antonino De Rosa - Posts: 47 |
Hello Sierra Team, i would like to trade the CL but i doesn`t find the Nymex for choose. What should I do and how much it costs ? Thank you Regards Antonino |
| [2021-01-15 18:22:30] |
| John - SC Support - Posts: 48547 |
You are setup to get real-time data for the NYMEX and all the rest of the CME Group through the Denali Exchange Data Feed. You will find the list of NYMEX symbols under the NYMEX section on your Find Symbol window as shown in the image below. Note that it is about 2 lines up from the bottom in this image: http://www.sierrachart.com/image.php?Image=1610734837587.png Expand that section for the NYMEX and select the CL contract you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-01-15 18:39:51] |
Hi John, many thnaks for assist. I found it from my self. Other question: When do you start your own Denali data feed for eurex exchange ? If I want to quit trading Eurex Exchange it isn´t more necessary to have the Sierra Chart Data feed right ? Only the Denali would be enough for the CME Bundle ( CBOT,Nymex,Comex and CME ) I´ll think about this change. And in case of that I quit Eurex I would like to know how i can adjust it until end of this month. Many thanks in advance. Best regards Antonino |
| [2021-01-15 19:01:48] |
We are still working on the new EUREX data that will be part of the Denali Exchange Data Feed. We do not have (or give) specific dates, as things happen and dates change. The only thing we can say is that we are very close, but there is still some work to be done.If I want to quit trading Eurex Exchange it isn´t more necessary to have the Sierra Chart Data feed right ? Only the Denali would be enough for the CME Bundle ( CBOT,Nymex,Comex and CME )
Yes, you are correct about this. If you are only trading the CME Group, then you would only need the Denali Exchange Data Feed.
| [2021-01-15 19:07:39] |
Okay, if i decide to quit the Eurex Exchange and the Sierra Chart data feed I´ll let you know for assisting this change. Deactivating the Exchange is easy but not sure how deactivate the SC data feed and which settings to put in the Data trade service settings. Enjoy your weekend thank you |
| [2021-01-18 04:47:37] |
There is nothing you need to do: but not sure how deactivate the SC data feed and which settings to put in the Data trade service settings.
