Date/Time: Thu, 20 Feb 2025 20:01:46 +0000
how to stop or disable sierra chart downloads
View Count: 569
[2021-01-15 18:02:17]
raja - Posts: 20
I hate sierra forcing me to download every day all the new
versions. How can i stop this ?
without my permission no version should be downloaded and I must
have an option to say NO to downloading the latest versions
bala
[2021-01-18 04:43:35]
What you describe is definitely not the case at all and never has been ever in the history of Sierra Chart. So we have absolutely no idea what it is you are referring to and it is not making any sense to us.
There are some less common scenarios where there is a forced update to a particular version or higher. For example, this would have applied recently to CQG users using older versions but you are not using CQG and therefore are not affected by this. And we cannot prevent a forced update. It is required to even use the service.
Date Time Of Last Edit: 2021-01-18 04:45:07
