Date/Time: Fri, 21 Feb 2025 18:28:16 +0000
Migration from Ninjatrader
View Count: 1007
[2021-01-15 15:24:26] |
Channas - Posts: 32 |
Hi, I'm just testing Sierra chart as trial. So far, it does work for me better than NinjaTrader which I'm currently with. My broker account is with Phillip Capital. Can you please provide me instructions on how to migrate my trading account to Sierra chart. Thanks |
[2021-01-15 15:40:28] |
John - SC Support - Posts: 38111 |
What Trading Service are you using with Phillip Capital right now?
[2021-01-16 21:21:21] |
Sorry I meant my broker is Ninjatrader and Philip Capital is clearing firm they offered. What specifics do you need to know?
[2021-01-16 23:57:12] |
You will need to move your account directly with Philip Capital and we recommend using the Sierra Chart order routing service: Sierra Chart / Trading Technologies Futures Order Routing Service: Introduction They do support the Sierra Chart order routing service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-16 23:58:15
[2021-01-17 19:09:35] |
Thanks. What's the monthly cost for this service? Also, I'm going to need data with market depth for Eurex (I read Denali exchange data are going to include Eurex data this month?). How much is the package? Are your Eurex commisions the same as for CME?
[2021-01-18 03:47:14] |
You can find the pricing for Sierra Chart packages here: Description of Service Packages and Pricing And you can find the pricing for the Denali Exchange Data Feed here: Denali Exchange Data Feed The EUREX exchange fee will be about 25 USD per month. In regards to commissions, you need to contact Phillips Capital about that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-18 03:48:05
[2021-01-23 22:18:28] |
Can I go with a multiple month discount package instead? Is Eurex high-quality data going to be included from my understanding? If so what is a difference between package 10 and 11? Description of Service Packages and Pricing: Multiple Month Purchase Discount |
