Date/Time: Tue, 25 Feb 2025 01:22:01 +0000
Chart trading + OCO orders
View Count: 821
[2021-01-15 14:13:21]
WhiskyTango - Posts: 8
Hi
on this page but couldnt really figure it out
Order Types: OCO Buy Stop Sell Stop
BUT, is it possible to enter a trade via right clicking a price level, select eg BUY LIMIT, and 3 "order lines" (eg sell stop, buy limit and sell limit order) pop up.
and also make them GTC, and 1% away from each other and apply to every instrument by default?
I Could do it on IB's TWS so hoping i can do it on SC too.
thanks
Date Time Of Last Edit: 2021-01-15 14:15:28
[2021-01-15 15:09:14]
John - SC Support - Posts: 38150
It sounds like you just need to use basic Stop and Limit orders for your Attached Orders. Refer to the example here:
Attached Orders: Simple Bracket Example
You can then enter your offsets as Percentage by changing the Offset Type to Percentage. Refer to the information here:
Attached Orders: Offset Values
[2021-03-30 00:12:46]
how do i set the SimpleBracket as my default order type to every chart, without having to open the trading Window?
[2021-03-30 14:17:59]
Refer to the following for one option:
Basic Trading and the Trade Window: Trade Window Linking
You can also setup Control Bar buttons to select Trade Configurations. Refer to the following:
Control Bar: Control Bar Trade Window Configuration Buttons
