Date/Time: Thu, 20 Feb 2025 19:53:42 +0000
Updating Problem
View Count: 641
[2021-01-15 10:17:39]
User942196 - Posts: 40
Dear friends
When i update from 2206 to 2207 all my Settings is lost. i tried directly to 2218 but the same thing.
how can i repair it?
how do i upgrade without losing my settings?
thanks
michael
[2021-01-15 10:19:40]
This does not make sense. There should not be any problem like this. What settings are you referring to?
[2021-01-15 12:55:57]
the control bar setting for sure return to default
i belive also other costamizations i did will default
i didnt check it becoause i immidetly reverted to 2206
i did it twice same problem
M
[2021-01-15 14:33:15]
John - SC Support - Posts: 38084
When you go back to 2206 all your customizations are still there?
[2021-01-15 14:50:59]
Yes
[2021-01-15 21:46:52]
Before updating again, delete the Sierra4.config file in the Sierra Chart installation folder.
You must have updated previously, gone back to an earlier version, made changes and then updated again.
[2021-01-17 19:26:57]
Thanks that made the trick!
