Date/Time: Thu, 20 Feb 2025 19:57:55 +0000
Attached Orders (Target and Stop) Canceled one day after the Open
View Count: 520
[2021-01-15 08:15:49] |
User993113 - Posts: 74 |
Dear Support, got a problem with a live OCO order, please consider I am using Denali data flow. I enclose order data on M6EH21. As you can see from documentation attached order has been calcelled in the very same time I logged in the day after the entry. As you can imagine it leaves me scared because I don’t know if I will either book the gain or will be protected by the stoploss. Can you please help me and investigate and solve the issue so I can trade knowing it works? Why the attached orders disappear? Is it, by chanche, in relation with Overnight session? Many thx, Massimo |
Private File |
[2021-01-15 10:24:47] |
Make sure the Time in Force is set to Good till canceled for the Attached Orders: Attached Orders: Time In Force Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
