Date/Time: Thu, 20 Feb 2025 20:11:47 +0000
Migration from NinjaTrader
View Count: 550
[2021-01-15 06:25:27] |
Channas - Posts: 32 |
I'm currently trading with NT8 feeding up with continuum data and my account is open with Phillip Capital. I'm contemplating to switch to Sierrachart. Any instructional guide I can follow if I decide to go ahead?
[2021-01-15 10:10:37] |
You definitely will need to move to a different broker. We recommend using the Sierra Chart Order Routing service: Sierra Chart / Trading Technologies Futures Order Routing Service The supported brokers is listed in this section: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
