Date/Time: Thu, 20 Feb 2025 20:09:26 +0000
ICE data with CQG
View Count: 545
[2021-01-14 20:44:03] |
User31044 - Posts: 33 |
Hello. I use TT-W (FIX) / Denali data feed. I need market data for ICE too, so I also need Sierra Chart CQG. Do I need another SC account, or just another instance of SC on my PC to connect to CQG?
[2021-01-14 21:10:03] |
We think AMP will be or currently does support ICE on TT. We are checking on this. And if you just need market data for ICE we can provide that to you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-14 21:10:17
[2021-01-14 21:13:21] |
We have confirmed that AMP will be supporting ICE on TT shortly. For the ICE market data use this data feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-14 21:27:16
