Date/Time: Thu, 20 Feb 2025 20:09:19 +0000
symbol is unknown
View Count: 618
[2021-01-14 19:45:21] |
User61576 - Posts: 445 |
i allready singed for the exchanges now I am getting an orange box with an error "symbol is unknown" also, do I need to do anything on a monthly basis? |
[2021-01-14 22:18:34] |
John - SC Support - Posts: 38089 |
It looks like you are setup to use the Sierra Chart Order Routing with Data Service, but you have not changed your Data/Trade Service Settings to this service. Follow the instructions at the following link starting at step #9: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions If you follow all the instructions in the link given, then this will resolve your orange box with a Symbol Unknown error. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
