Date/Time: Sat, 19 Sep 2026 13:59:18 +0000
Market Depth not updating
View Count: 1516
| [2014-02-21 02:41:38] |
| User81947 - Posts: 2 |
I'm using OEC, only want NQH4 data, and since I downloaded ver1089 I'm not getting a refresh of the market depth info apart from the initial download when I open up sc. The old figures do not reset, although now at least since 1092 I'm getting some update close to the price with all the previous and redundant hanging around and that info being added to other calculations. |
| [2014-02-21 03:26:17] |
We know about this and we have pointed it out to OEC. We will contact them again about it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-02-21 09:10:53] |
The market depth issue is now resolved. Update Sierra Chart by selecting Help >> Download Prerelease.
| [2014-02-21 10:37:12] |
Thanks, all good.
| [2014-02-21 11:47:10] |
| Bedhog - Posts: 187 |
Thank you.
Date Time Of Last Edit: 2014-02-21 11:53:38
