Date/Time: Thu, 20 Feb 2025 20:01:26 +0000
Quantity and Price Buttons A C
View Count: 762
[2021-01-14 15:58:29] |
User754053 - Posts: 15 |
Dear Sierra-Chart Support, By clicking on "modifying quantity" of an order in chart, you open the "Quantity and Price" window. Getting in the input mask of quantity gives you four buttons "+, -, A, C". (Check attached picture) What is the purpose of "A" and "C" buttons? Nothing seems to happen when i click on them. I could not find anything in the help panel as there are only old pictures of this menue. Best Regards |
[2021-01-14 18:43:04] |
John - SC Support - Posts: 38087 |
Right now the A and C buttons do the same thing, which is just to Accept the entry that was made. It is the same as hitting the Enter key after having entered a value. We are working on documentation for these new Sierra Chart Windows and should have it ready in the next few days. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-15 22:47:13] |
We have created some initial documentation to explain how to interact with the new Sierra Chart Windows. You will find the documentation here: Getting Started, Opening Charts and Basic Trading: Working with Sierra Chart Settings Windows Note that the "C" button will be changing to perform a Cancel for that field. This is explained in the documentation linked above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
