Date/Time: Wed, 09 Sep 2026 04:14:03 +0000
1 Minute Charts not updating with TD Ameritrade Data
View Count: 4266
| [2014-02-20 23:05:12] |
| lou_diamonds - Posts: 39 |
Hi, I'm using TD Ameritrade Data & for some reason I have a chartbook that has some 1 minute charts that will not update. What I mean by this is that, I open the charts after market hours. I haven't opened them at all during market hours. Then, when I open them, I have to hit Edit -> Delete all Data and Download. Is there a way to do this where I can do one click & update all the charts at once? Or better yet, can I set the charts to update when I open them? Thanks |
| [2014-02-22 05:53:04] |
The data will be downloaded when the charts are open and you are connected to the data feed. There will not be trouble with this, unless there is a server-side issue. To do what you want is documented here: https://www.sierrachart.com/index.php?l=doc/helpdetails7.html#DeleteDownloadAllCharts The reason for the delay with responding is we needed to prepare documentation for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
