Date/Time: Wed, 19 Mar 2025 03:48:55 +0000
Delayed Data NQ
View Count: 623
[2021-01-13 16:47:14] |
RobertoC - Posts: 7 |
Hello, I have noticed that I have some delay in the data feed for NQ. I am using NinjaTrader 8 with Rithmic data to place orders and using SC with Denali for analysis. The data in SC is quite slow compared to NT8 with Rithmic, especially comparing the Footprints of the two data feeds. I also trade the ES, GC and CL and they all work just fine, it seems to be only NQ to have this issue. Is there anything I can do to improve it? Thanks
[2021-01-13 17:51:08] |
Refer to this help topic: Prices / Data Falling Behind Also make sure that the real-time data compression setting is set to Standard Compression: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#UseRealTimeDataCompression Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-13 18:07:48
