Date/Time: Sun, 23 Feb 2025 02:26:10 +0000
[User Discussion] - Maximum Volume
View Count: 991
[2021-01-13 15:10:24]
User737360 - Posts: 23
Does Sierra Chart have the setting that you can display the maximum volume from a different time period? Unfortunately I did not find the function.
Thank you and beste regards
Noah
[2021-01-13 15:29:00]
John - SC Support - Posts: 38116
There is not a study specifically to do this, but you should be able to use the Spreadsheet Study using the MAX function to accomplish what you need. Refer to the information here:
Working with Spreadsheets: Introduction
And for the MAX function, here:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#MAX_Function
[2021-01-13 17:04:33]
Ackin - Posts: 1865
High/Low for Time Period | High/Low for Time Period - Extended
Input Data High: This can be changed from the default and set to the particular Study Subgraph to use as the High when this study is based on another study. For further information, refer to Input Data.
Input Data Low: This can be changed from the default and set to the particular Study Subgraph to use as the Low when this study is based on another study. For further information, refer to Input Data.
[2021-01-25 17:23:14]
Is it possible to have the POC (Point of Control) displayed for a certain period of time?
[2021-01-25 18:52:28]
We do not know exactly what you mean by "for a certain period of time", as there could relate to a few different things.
In general refer to the following studies for the POC:
Volume Value Area Lines
TPO Value Area Lines
[2021-01-25 19:12:50]
For example, I would like to know the POC (from 11/23 - 11/29/2020). Or for example the POC from 22.10. - 25.11.2020.
I would like to know the highest volume of a certain time period.
[2021-01-25 20:59:43]
For the Volume POC, you could use the Volume by Price study and setup the time period as you want in there and then you can get the POC value from the first subgraph. Refer to the information here:
Volume By Price Study
As to the highest volume that has been answered above.
[2021-01-26 05:03:28]
Is there also the possibility that I can display the highest volume of a contract (for example in CL)?
[2021-01-26 09:23:32]
Have a look at just using the Volume study:
Volume
And set the chart bars to whatever time period that you want.
[2021-02-03 09:24:10]
I think we have misunderstood each other. On my pictures you can see the exact description.
attachmentMaximum Contracts.pdf - Attached On 2021-02-03 09:20:42 UTC - Size: 136.19 KB - 247 views
[2021-02-03 11:01:56]
Use the Volume by Price study for this:
This is the particular Example Settings you will want to follow:
Volume By Price Study: 1 Day Volume Profiles Across Entire Chart
[2021-02-03 11:43:50]
Do I have to follow this instruction or which?
attachmentSC.pdf - Attached On 2021-02-03 11:43:37 UTC - Size: 91.9 KB - 267 views
[2021-02-04 05:17:42]
Did you mean the setting under Window -> Tool Values Window?
[2021-02-04 05:52:54]
The "Tool Values Window" is actually exactly what I was looking for, but I can't set specific days (for example, 01/06/2021 - 01/09/2021) so I can see the POC from 01/06/2021 - 01/09/2021. I can only select a day with the "Crosshair". Are there any other possibilities?
[2021-02-08 19:34:58]
