Date/Time: Wed, 23 Sep 2026 06:43:51 +0000
Bid/Ask line in DOM
View Count: 1467
[2021-01-12 23:13:37]
Nicogou21 - Posts: 12
Greetings,
I was wondering if it was possible to a line in between the Bid/Ask as they do for other plateforms such as Jigsaw.
You have a static line which enables you to keep an eye on the Price Action, linear to the other markets when you want to scan the situation.
Is it possible?
Many thanks,
imageLinear Line between Bid-Ask.PNG / V - Attached On 2021-01-12 23:13:12 UTC - Size: 1 MB - 359 views
[2021-01-13 18:04:02]
Have a look at this setting:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Best Bid/Ask Box Background
[2021-01-15 06:45:34]
Thank you for the information.
I was able to find the "re-center Trade DOM scales" but how Put the line where the price is at between the Bid/Ask? And how can I program it to re-center after 2 ticks movements, automatically?
Regards,
Nicolas.
[2021-01-15 10:17:12]
There is no support for this.
Have a look at using a constant range scale and there are various options for controlling that:
Chart Scale and Scale Adjusting: Constant Range (Scale Range)
Date Time Of Last Edit: 2021-01-15 10:17:33
