Date/Time: Mon, 25 Nov 2024 16:41:31 +0000
[User Discussion] - drawing rectangle automatically for es charts 2 points below the previous high
View Count: 1251
[2014-02-20 20:11:48] |
mario mario - Posts: 22 |
I have been drawing a rectangle manually everyday 2 points below from the previous day high for es charts, can I automate it using spreadsheet or some other drawing tools to draw rectangle automatically from open to close with 2 points range from previous day high mario |
[2014-02-20 21:16:45] |
For the documentation for the Spreadsheet study, refer to: http://www.sierrachart.com/index.php?l=doc/doc_WorksheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
