Date/Time: Thu, 19 Sep 2024 16:13:38 +0000
Show drawing behind study
View Count: 1432
[2014-02-20 19:19:21] |
AkTrader - Posts: 13 |
I've put a horizontal line on my cumulative delta study. How do I get the line to show behind the cumulative delta bars? I've turned on/off "opaque Label Background" in the horizontal line properties but it doesn't do anything.
[2014-02-21 00:55:32] |
There is a setting for this in Chart >> Chart Settings >> Advanced Settings. We also recommend referring to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
