Date/Time: Mon, 21 Apr 2025 23:27:29 +0000
Stock Trading Footprint
View Count: 2338
[2013-04-19 01:36:55] |
iafayte - Posts: 11 |
I know cumulative delta and footprint (bid vs offer volume analysis) is commonly used in Futures trading...but is it possible to get stock data such as Nasdaq exchange data from IQFeed and be able to use volume profile, cumulative delta, and footprint? Will the delta and volume be accurate from IQfeed nasdaq stock data? |
[2013-04-19 03:24:04] |
Sierra Chart does support Numbers Bars and Cumulative Delta Bars for all markets where there is bid volume and ask volume. When using IQ Feed, you will have both historical and real-time bid volume and ask volume for stocks.
[2025-02-11 13:23:15] |
User973508 - Posts: 2 |
I am trying to use numbers bars with ttf from IQfeed in sierra Chart but it says the service package does not support this function even though I have sub 11.
[2025-02-11 17:30:52] |
Please get us your Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
