Date/Time: Mon, 25 Nov 2024 16:46:22 +0000
T4 historical data issues
View Count: 1045
[2014-02-20 18:51:46] |
User50323 - Posts: 7 |
Is there an issue with getting historical data with T4 today? A lot of instruments only load intraday data for 02/20...
[2014-02-20 20:10:11] |
This we would not be aware of because the service is provided by CTS. With this kind of problem, you need to refer to these help topics: https://www.sierrachart.com/index.php?l=doc/helpdetails7.html#RetryDownloadDataInChart https://www.sierrachart.com/index.php?l=doc/helpdetails6.html#h6.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-20 20:10:31
