Date/Time: Mon, 25 Nov 2024 16:40:55 +0000
Stopped receiving $TICK data
View Count: 1002
[2014-02-20 18:25:10] |
User025822 - Posts: 35 |
I am currently trading a live account with AMP/TTNet and since Tuesday I stopped receiving $TICK (NYSE Tick) data. No quotes or anything. Before that I was getting it no problem. Has there been any changes? I am getting an error message,when I disconnect and reconnect, of 'Symbol is unknown' on the $TICK chart that used to work last week. Tried to update Global Symbols from Server but that didn't solve the problem Thank you Date Time Of Last Edit: 2014-02-20 19:17:20
[2014-02-20 20:20:11] |
You need to use the new Market Statistics symbols. Here is the documentation for them: https://www.sierrachart.com/index.php?l=doc/SCMarketStatistics.php The new symbol is TICK-NYSE Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-20 20:20:24
