Date/Time: Fri, 11 Sep 2026 09:56:34 +0000
How many charts can I run at the same time
View Count: 1684
[2014-02-20 18:22:38]
GCAdmin - Posts: 35
I am wondering how many charts in each chartbook and how many chartbooks I can run at the same time on my charting software. They would all be forex pairs running on the SC Forex Data feed. I just wanted to check to see what you would recommend. I don't want to be running to many and have issues with data slowing down or charts freezing, etc. Are there any modifications that I could make to my computer to run more charts at a time?
Thanks!
[2014-02-20 21:40:23]
There is no limit imposed by Sierra Chart. You just have to do your own testing to see what works best for you and your computer system.
If you do have a large number of charts open, we do recommend setting the Global Settings >> General Settings >> Chart Update Interval to 1000 or a little higher.
