Date/Time: Wed, 19 Feb 2025 01:00:11 +0000
Wrong numbers in volume profile after update
View Count: 460
[2021-01-10 11:01:54] |
User541842 - Posts: 34 |
Updated to the newest version and the numbers in volume profile are wrong. how to fix that? |
Attachment Deleted. ![]() |
[2021-01-10 11:08:49] |
Change this setting to 1: Chart Settings: Volume Value Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Also this issue will not occur in the latest prerelease. But it does not normally occur. It only occurs if symbol settings are not known at the time of the chart being opened. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
