Date/Time: Wed, 19 Feb 2025 01:16:37 +0000
Bitcoin chart not available for CME
View Count: 893
[2021-01-08 23:34:12] |
User525965 - Posts: 153 |
Hi, I'm trying to pull up a chart for bitcoin and its not showing anywhere under available markets CME exchange. I'm using TT data on a simulated tryout account. Is the symbol not available through TT or is there a way I can add it? |
[2021-01-09 03:41:52] |
You are not using TT data. You are using the Denali Exchange Data Feed: Denali Exchange Data Feed We have now added the CME BTC symbol to the trading evaluator service. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-09 04:56:48] |
Thanks. I updated from the server and disconnected a couple times but I dont see BTC under CME still.
[2021-01-09 05:01:04] |
I got it now. Thanks!
