Date/Time: Wed, 19 Feb 2025 00:44:39 +0000
crypto data
View Count: 683
[2021-01-07 22:57:11] |
jeffrey kurdilla - Posts: 3 |
i was reading how to setup a crypto data feed, but will that change all my settings for data and trading for futures. it seemed i was making a global change by following your instructions for crypto
[2021-01-08 00:47:32] |
Sierra_Chart Engineering - Posts: 18484 |
The first thing you need to do is you need to update to the current version of Sierra Chart: Software Download: Fast Update We see you are also using CQG so please be aware of the following: Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG We recommend installing a second installation of Sierra Chart: Using Multiple Data and Trading Services at the Same Time And then use it for the crypto currency data: Cryptocurrency / Bitcoin Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-08 00:48:06
