Date/Time: Wed, 19 Feb 2025 00:54:07 +0000
Rel. 2215 64-bit: Modify Text doesn't work as expected
View Count: 512
[2021-01-07 22:43:33] |
gayer2428 - Posts: 91 |
On any text manually created on chart, Modify Text feature doesn't allow the option of changing font type, font size or reverse text color. It simply opens a pop-up window with the text on it. Please check. Thanks.
[2021-01-08 00:51:01] |
What you need to do is right-click on the text drawing and select Chart Drawing Properties to change these. Refer to: Chart Drawing Tools: Chart Drawing Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
