Date/Time: Wed, 19 Feb 2025 00:54:07 +0000
VOLUME ERROR
View Count: 517
[2021-01-07 20:09:16]
User380937 - Posts: 1
I have a problem: the Sierra platform gives me the wrong volume data. I have checked with my data provider, and the error is in Sierra. What can be the motive?
[2021-01-07 22:19:57]
Specifically where in Sierra Chart are you looking at this volume data?
Also you are using CQG and you must follow the instructions here regarding historical data:
Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG | Post: 245144 (also linked below)
Please be aware of the following regarding CQG historical data:
We are no longer as of December 28, 2020 providing the Sierra Chart provided historical data service for CQG or Interactive Brokers users. For more information, refer to this Support Board thread:
Also refer to this post for steps that you need to do now:
The solution to this problem is to use the Denali Exchange Data Feed for CME and EUREX (Upcoming in January 2021) data. Step-by-step instructions are here:
The first calendar month of this data feed is free. Let us know if you need help with the set up and we will help you through all of the steps.
In the case of CQG you will then need to contact your broker and cancel CME and EUREX exchange fees through your CQG account so you do not pay exchange fees twice. You definitively do not have to pay any market data exchange fees through your brokerage account to CQG. This is not required.
For other exchanges (ICE, HKFE) you need to use the Sierra Chart Exchange Data Feed:
As an alternative to CQG, we recommend using the Sierra Chart Order Routing Service:
Sierra Chart / Trading Technologies Futures Order Routing Service
In regards to using CQG provided historical data, we definitely do not recommend using that. It has an additional cost of 25 USD per month. The data delivery is slow and inefficient and causes Sierra Chart to freeze during the processing of it. Only 5 days of tick data is supported from CQG. And only current futures contracts are provided.
Whereas with Sierra Chart provided data feeds, you will have access to 10+ years of reliable high-speed delivered tick by tick data. Once again we do not advise using CQG historical data and it will not work well with Sierra Chart. And we also provide no technical help or support for any CQG provided historical data or real-time data.
Date Time Of Last Edit: 2021-01-07 22:27:34
