Date/Time: Wed, 19 Feb 2025 01:03:14 +0000
formulae of builtin studies
View Count: 585
[2021-01-07 17:31:33]
User250840 - Posts: 37
you could I find the actualal formulae of built in studies ? for educational purposes
Date Time Of Last Edit: 2021-01-07 17:32:58
[2021-01-07 17:46:52]
John - SC Support - Posts: 38036
All of the formulas for our built-in studies are listed with our documentation for the study.
For example, the formulas that are used for the Connie Brown Composite Index are found on the documentation page for that study, which is here:
You will find the entire list of studies in the Technical Studies Reference, which is this page:
[2021-01-08 17:24:39]
ForgivingComputers.com - Posts: 1008
The easiest way to do this is to click the Description button on the Study Settings Window.
