Date/Time: Wed, 19 Feb 2025 01:10:06 +0000
Minor Trade Activity Log Problem - Entries not deleting on first attempt.
View Count: 455
[2021-01-07 16:13:45] |
owendonk - Posts: 54 |
When I go to Trade Activity Log, select an entry, go to Edit, and click Delete Trade Activity Entry, sometimes nothing happens the first try. The second try it usually works. This also happens with selections of entries. Again, no big deal but you guys are perfectionists haha.
[2021-01-07 23:34:52] |
Most likely the issue is what is described here: Trade Activity Log: Trade Activity Not Displaying or Clearing (Improving Trade Activity Query Performance) Also make sure Sierra Chart is up-to-date. Another thing is that after you complete the operation, then wait a few seconds, and then select Edit >>Refresh Log. If that updates the list, then maybe there is a problem with the refreshing not always working properly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
