Date/Time: Thu, 26 Nov 2026 16:38:08 +0000
Numbers bar study
View Count: 1822
| [2014-02-20 15:02:41] |
| User66360 - Posts: 81 |
I use tans act and it says the numbers bar study is not allowed. How can I enable this? Is there a way I can get a trail period with it to see if its useful? Thanks
| [2014-02-20 21:13:43] |
Refer to this page: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html We have activated your account you have logged into this Support Board with, for a 7 day trial. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-02-20 21:18:30] |
So I need to sign in with my Sierra charts to try it, not trans act for the trial period? Thanks
| [2014-02-20 21:42:15] |
Yes. Log into Sierra Chart with your own Sierra Chart account name.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-20 21:42:25
| [2014-02-20 23:31:30] |
Thanks for the help!
