Date/Time: Wed, 19 Feb 2025 01:18:27 +0000
Transfer to new PC, customized toolconfig not copied
View Count: 487
[2021-01-07 12:40:01]
User752429 - Posts: 1
The transfer of SC to an new computer succeed but the customized toolbar configuration is not visible on the new computer.
I copied the whole C:SierraChart directory to the new computer. Started over and over again, inspected 'Sierra3.cfg' in explorer and the size on old and the new PC is the same. I already deleted the 'SierraChart_64' in the SierraChart-directory and reinstalled it, but the toolbar configuration is still the 'default' toolbar. How can I fix it?
[2021-01-07 16:40:31]
The Control Bar configuration is located in the Sierra3.cfg file. Check all 8 Control Bar configurations under the Global Settings menu to see if they are there. They must be.
Date Time Of Last Edit: 2021-01-07 16:41:06
