Date/Time: Sat, 12 Sep 2026 17:34:30 +0000
S&P chart is frozen
View Count: 711
| [2021-01-07 10:47:08] |
| User270282 - Posts: 2 |
hi, my S&P chart only keeps freezing every time i load up my sierra charts, all other charts are working completely fine, i delete and re download the data and loads up to the current time but never works after that |
| [2021-01-07 15:32:04] |
| John - SC Support - Posts: 47854 |
Most likely, you are not using the correct symbol for the S&P consistently and there is a symbol conflict. To quickly update the symbols select Edit >> Translate Symbols to Current Service. Refer to the documentation here for this: Edit Menu: Edit >> Translate Symbols To Current Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-07 16:42:44
