Date/Time: Wed, 19 Feb 2025 01:12:04 +0000
BTC USD
View Count: 1129
[2021-01-06 23:03:42] |
User294114 - Posts: 1 |
Hello There use to be BTC/USD IN CFD-FXCM but i cant see it anymore.Where can i find it Thanks |
[2021-01-07 01:24:03] |
This is no longer available. You need to use one of the other crypto currency symbols available. Refer to: Cryptocurrency / Bitcoin Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
