Date/Time: Thu, 17 Sep 2026 09:04:54 +0000
Chart Update Interval in Ms
View Count: 1749
| [2014-02-20 14:24:19] |
| Carl71 - Posts: 125 |
Can you set the Chart Update Interval for each single chart? I trade only 1 market and I like to set the Chart Update down to 10/40 ms But, I noticed that this better performance tend to increase the CPU Usage So I would like other chart set up to 4/500 ms in order to decrease the CPU Usage If this is not possible, your advice could be to use two separate copies of SC? one with Chart update down to 40 ms and the other with the rest of markets charts up to 400/500 ms? is it feasible? Thanks Date Time Of Last Edit: 2014-02-20 14:26:57
| [2014-02-20 21:35:16] |
The way this would have to be done is to use two copies of Sierra Chart and that would be reasonable.
| [2014-02-21 14:57:36] |
I use infinity AT with AT Chart service Since the platform is launched with their software, how can I launch the second copy of Sierra Chart? |
| [2014-02-21 18:14:57] |
You need a direct account: http://www.sierrachart.com/index.php?l=doc/doc_DirectAccount.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
