Date/Time: Wed, 19 Feb 2025 00:51:23 +0000
TT _order message
View Count: 523
[2021-01-06 15:15:21] |
AB604E - Posts: 32 |
Hi SC, I have got this error , what is the "{New order originated from external service" meant ? Since only way to enter order is via Sierrachart or Web. The current open position is assume zero from the control panel . Info Text: TT order update (Rejected). Text: Exceeds credit limits | SenderSubID: New order originated from external service Thanks Date Time Of Last Edit: 2021-01-06 18:16:01
[2021-01-06 17:33:08] |
Info Text: TT order update (Rejected). Text: Exceeds credit limits | SenderSubID: 46840AB | New order originated from external service
You need to contact your broker about this: Exceeds credit limits Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
