Date/Time: Thu, 19 Sep 2024 16:39:36 +0000
stock symbol ib
View Count: 1113
[2014-02-20 13:34:01] |
User37054 - Posts: 8 |
What's the symbol for MSFT @IB I tried MSFT-STK-SMART/NYSE, no success ? btw, this is much too difficult !! |
[2014-02-20 13:38:59] |
Yes, it is difficult because Interactive Brokers makes it difficult. It is not difficult because of Sierra Chart. You should be hearing from other users later today about what they are using that works. We are not quite sure. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-22 10:14:05] |
We can see that no other Interactive Brokers user responded with suggestion. We apologize for that. What we know is that the problem with this symbol has to do with NYSE MSFT-STK-SMART/NYSE Therefore, enter MSFT into the quote board in Trader Workstation and then open up the contract description for it and see what are the available primary exchanges and then just try one of those when specifying the symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
