Date/Time: Tue, 04 Mar 2025 07:51:17 +0000
Download Failed Error downloading histrorical Intraday data
View Count: 1156
[2021-01-05 21:59:50]
User213674 - Posts: 2
Dear sierra chart,
i can't download charts and i can't see fully intraday charts.
i see following message: Download Failed Error downloading histrorical Intraday data for F.US. YMH21. Data for instrument F.US.YM (corresponding to ID5) is not allowed.
Result=103. Num Quotes=0.
Attached i send you screenshorts of my sierra chart software.
[2021-01-05 22:39:11]
We are no longer as of December 28, 2020 providing the Sierra Chart provided historical data service for CQG or Interactive Brokers users. For more information, refer to this Support Board thread:
Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG
Also refer to this post for steps that you need to do now:
Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG | Post: 245144
The solution to this problem is to use the Denali Exchange Data Feed for CME and EUREX (Upcoming in January 2021) data. Step-by-step instructions are here:
The first calendar month of this data feed is free. Let us know if you need help with the set up and we will help you through all of the steps.
In the case of CQG you will then need to contact your broker and cancel CME and EUREX exchange fees through your CQG account so you do not pay exchange fees twice. You definitively do not have to pay any market data exchange fees through your brokerage account to CQG. This is not required.
For other exchanges (ICE, HKFE) you need to use the Sierra Chart Exchange Data Feed:
As an alternative to CQG, we recommend using the Sierra Chart Order Routing Service:
Sierra Chart / Trading Technologies Futures Order Routing Service
In regards to using CQG provided historical data, we definitely do not recommend using that. It has an additional cost of 25 USD per month. The data delivery is slow and inefficient and causes Sierra Chart to freeze during the processing of it. Only 5 days of tick data is supported from CQG. And only current futures contracts are provided.
Whereas with Sierra Chart provided data feeds, you will have access to 10+ years of reliable high-speed delivered tick by tick data. Once again we do not advise using CQG historical data and it will not work well with Sierra Chart. And we also provide no technical help or support for any CQG provided historical data or real-time data.
[2021-11-30 03:59:21]
IAMSPARTACUS - Posts: 36
I have a similar issue. Don't know what the problem is. I have attached a photo for you to see the error message.
Private File
[2021-11-30 14:32:57]
This is caused by a connectivity issue to the server. Not sure what we could do to help with this. In general refer to this help topic:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
You can try the download again with this command:
Edit Menu: Edit >> Download Data from End of Chart
Date Time Of Last Edit: 2021-11-30 14:33:50
