Date/Time: Wed, 19 Feb 2025 00:06:43 +0000
Feature request - simple chart dropdown for linking
View Count: 466
[2021-01-05 11:15:37] |
HeyUgly - Posts: 251 |
hey there question if its possible to put the chart linking option as a simple dropdown on the charts itself? i find it takes a long time to link a set of chartbooks by having to constantly go into the menu, also when selecting which things you want to link, {session times, symbol etc} to have to go back into the menu each time it a time burner. would be great if you could incorporate these into a simple dropdown on that charts? ive looked into options seeing if you can do this already but have found nothing thanks in advancew! |
[2021-01-05 11:30:17] |
User907968 - Posts: 831 |
Working With Charts: Chart Linking 'Chart Linking through Control Bar Buttons' or 'Chart Linking through Link Number Field on Region Data Line' |
