Date/Time: Wed, 19 Feb 2025 00:17:39 +0000
Bar Value Randomly Returning decimal places ending with XXX.998047
View Count: 488
[2021-01-05 06:04:18] |
Eddie - Posts: 12 |
Found an error on system randonmly returning decimal places of bar value ending with XXXXX.998047 when programming is made. For example, Bar high = 27345.998047. System is unable to return an integer value.(i.e. 27346). When non-integer value is returned, value is always ended with XXXXX.998047. Chart setting screenshot is attached for your reference. |
[2021-01-05 07:17:20] |
Eddie - Posts: 12 |
Add one more comment. When system returns non-integer values randomly, the values always end with the decimal places like XXXX.998047.
[2021-01-05 08:10:54] |
In regards to this, refer to: ACSIL Programming Concepts: Floating Point Value Error Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
