Date/Time: Wed, 19 Feb 2025 00:33:43 +0000
[Programming Help] - Send data to DTC Server
View Count: 563
[2021-01-05 04:39:17] |
User111602 - Posts: 17 |
Trying to use sierra to chart custom symbols in realtime. How would one feed data into the DTC server so it can be used within Sierra for charting?
[2021-01-05 08:12:19] |
You need to develop a network socket based server. More information is on this page: Data and Trading Communications (DTC) Protocol Test Client So within Sierra Chart you will use what is called the DTC Service client. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
