Date/Time: Wed, 19 Feb 2025 00:30:36 +0000
Always Simulate Bid and Ask Prices During Replay
View Count: 543
[2021-01-05 00:31:56] |
Mr.DaxF - Posts: 45 |
hello dear support, i will request how i can activate this setting doe the new setting style inside the Sierrachart software? when i go straigth tha way like the instruction from "how i can used backtest via sierrachart" than "Chart >> Chart Settings >> Advanced Settings 3 Always Simulate Bid and Ask Prices During Replay setting" but i didnt find it. can you assist me please to find it. regards |
[2021-01-05 01:40:51] |
It is there on the Advanced Settings 3 tab of Chart Settings. Check again. It is on the left side.
